By Gksportster
#10310
Hello I went to tap plastics and ordered some pvc 1/8” and when I got it home they sold me fpvc
It seems way to floppy to work as any support for door panels .
Did they sell me the wrong stuff ?
Thank you kelly
Ps John or any one where do you get 1/8” staples for the bea 71/16-421 ?
I’ve searched all the smallest I can find are 1/4” in johns video he recommends 1/8” .
One last thing
I’m working on a 1938 Oldsmobile business coupe and was wondering how you would attach panels in the trunk area like one in this pic
Thank you kelly
#10311
Gksportster wrote: Sat Apr 11, 2020 4:16 am Hello I went to tap plastics and ordered some pvc 1/8” and when I got it home they sold me fpvc
Thank you kelly
One last thing
Thank you kelly
@Kelly, I do believe they sold you the wrong product. I think they sold you foam board and you want solid PVC. John does not normally use PVC but I do and like it a lot.
I think you will find a good staple assortment at an upholstery supply jobber. The BEA 71 gun is very popular with trimmers.
As far as mounting the panels go, Velcro is your friend. You can attach small angle brackets all kinds of ways. Double sided trim tape, epoxy cement, or panel adhesive all work. From there you can attach your panels with Velcro.
John Long
By Gksportster
#10312
Thank you John long.
The store called back and said they sold me pvc foam board.
I just want 1/8” pvc solid is that what it’s called ?
In his videos I baught he was working with pvc
Also I went out and noticed my doors they are not flat they are curved.
Thank you for the ways to attach panels in the trunk area
#10313
You are certainly welcome. It is good when you feel like you actually can help.
BTW, the regular PVC board can be formed with a heat gun. You must be careful not to over heat it though.
John Long
Gksportster, John liked this
By Gksportster
#10315
I was out working on the coupe and noticed their was these slots in the metal on the doors that has nails in it they look like Concreat nails just tack nails with twisted shank on it I’m assuming that’s is what they used to hold on the door panels and wind lace ?
I’m not sure I’m just guessing :thinking:
#10318
Yup. GM did that for years. Just do away with those and use door panel clips. You will need to drill holes for them. John with "The Lucky Needle," and owner of this forum, has an excellent tutorial on building door panels. Search "The Lucky Needle" on YouTube. I think he had 3 or 4 videos covering the door panels. They are excellent!
John Long
By Gksportster
#10322
Yea thank you
I’ve baught all the videos he has made.
I’m making rear arm rests and attaching them to the b piller and was wondering how much I should allow for the wind lace I was thanking 1/8” but not sure.
Would you know ?
Here is a pic
#10323
With all due respect, John normally uses ABS plastic for door panels. I double checked that on his door panel course. The ABS is great, I'm sure, but I have never used it.
I would think you are in the ball park with 1/8 -3/16 for the wind-lace and the wrap around for the arm rest.
By Gksportster
#10325
You are correct he did say abs.
So is it better to use abs then pvc ?
Now I’m wondering if I need the abs for the roof and deck lid or all abs ?
I have to meet with the manager at tap plastics tomorrow at noon pacific time :sweat:
#10326
Remember, I have never used ABS so I can not give you a good comparison. I like the PVC and have never had any reason to use anything different, not to mention, I paid 22 dollars for the last 4x8 sheet I bought. I am sure the ABS is good or John would not use it.
John Long
By Gksportster
#10327
Yea I know John wouldn’t use it if it was good.
I also read to use the pvc foam board like I have.
The pvc foam board that I have was 60 a 4x8 sheet and the solid pvc is 93 a 4x8 sheet.
The solid pvc will form the compound curves on a 1938 coupe roof and same on the trunk ?
Thank you for your help
I sent John the owner a message but some times it takes days to get a response.
I’m sure he’s busy
#10328
That is way too much for PVC. See if you have an Advanced Plastics Inc in your area. At least shop some and make sure that is the best you can do.
John Long
By Gksportster
#10329
Thats all we have around here if I exchange all 3 sheets it’s another 106 dollors on top of the 170 I already payed.
I’m wanting to do a smooth custom head liner and not use the hanging rod style but I’m not sure yet how I’m going to do it yet I’ve looked for chip board locally and no one knows what I’m talking about so I’m probably going to have to order from albrites that John recommends I just thank shipping is going to cost on the sheets.
I just went out and looked at the fpvc their is no way that will work unless it’s supported fully on the back panel but my car has large voids where their is no metal and if someone put their arm agents it it would flex a lot
#10330
Again. shop around. Chip board is only cardboard. Normally they sell the PVC or ABS in 3m (1/8”) but it is available in thin 1m. the chip board is kind of a low end product frequently used for patterns. Stop by an auto trim shop in your area and ask them where they buy their material.
Where are you located?
By Gksportster
#10331
Washington state
I’ve went to a few shops and I found one where the guys willing to help but he’s been closed since March before we got the stay at home orders.
I’ve called and left messages when we can go back to work I will see if I can get ahold of him and see if he can get me some he was going to get my pvc he said around 100 a sheet so he wasn’t making much off it and the jute padding he said was 15 a yard and carpet was 45 a yard
And I cannot find dap weld wood hhr glue locally
#10333
I wish I could help you with material but have no knowledge of your part of the country. You can buy the glue on Amazon or Ebay. I have used Albrights and Russion upholstery supply on line but I am sure there are on line suppliers close to you. Russian is in Arkansa. I forget where Albright's is. I will be surprised if either have ABS or PVC.
One more thought. Call a couple of sign companies in your area and see what they can supply you with.
By Gksportster
#10334
Thank you the pvc is already paid for so that’s mine just to use the solid I have to pay more but for the rest I will shop around I saw that amazon sells the glue
I’m going to order the glue and jute and carpet and panel clips all at the same time from your auto trim .com store next week I hope Tuesday my sound deadener arrives thank you for your time on another post I’ve posted is a pic of the car.
I’m going to put jute pad on the whole inside of the car after the sound deadener will a gallon be more then enough of the glue sorry for all the questions upholstery is all new to me I’ve watched videos and read books.
So far I’ve done everything on the coupe.
I’m trying to decide if I want to buy a used sewing machine and have the learning curve to reupholster the seat of have the shop do it the guy said 500 to 800
By Gksportster
#10342
I went their today.
I got 3 sheets of abs 1/8
Tomorrow the sound deadener shows up so the fun will start soon
